Build(deps): Bump logster from 2.9.2 to 2.9.3 (PR #10499)
Bumps logster from 2.9.2 to 2.9.3.
Changelog
Sourced from logster's changelog.
CHANGELOG
  • 2020-08-20: 2.9.3
    • FIX: fix code that causes warning from recent redis gem
  • 2020-08-11: 2.9.2
    • FIX: report_js_error incorrectly denying logs when Redis#exists returns integer
  • 2020-07-20: 2.9.1
    • FIX: Missing application backtrace in chained loggers.
  • 2020-06-11: 2.9.0
    • FEATURE: Allows JS errors to specify a log severity
    • DEV: Several dependencies upgrades
    • FIX: Don't search if the phrase hasn't changed
    • UX: Distinguish the value of the current env from the values of other envs in a merged message
  • 2020-03-30: 2.8.0
    • FEATURE: Upgrade icons to Font Awesome 5
  • 2020-03-03: 2.7.1
    • FIX: Stop env mutation to allow all chained loggers to have the same env (#110)
  • 2020-02-26: 2.7.0
    • FEATURE: Make log message max length configurable and bump the default to 2000 (#109)
  • 2020-02-17: 2.6.3
    • FIX: Respect redis namespace when fetching env using LUA
  • 2020-02-09: 2.6.2
    • FIX: Regression with rendering single env when env_expandable_keys config is present
    • DEV: Fix Ember deprecations in tests
    • DEV: Add more tests to env rendering
    • FIX: Backtrace frames from gems should be linkified even when they don't start with gems_dir
    • DEV: Allow Ember server to inherit preload data from Sinatra server
    • FIX: Fetch env when navigating through grouped messages
  • 2020-02-07: 2.6.1
    • FIX: Fetch env when row is selected to allow copy to work on Firefox
Commits
GitHub
