Build(deps): Bump loofah from 2.11.0 to 2.12.0 (PR #14018)
Bumps loofah from 2.11.0 to 2.12.0.
Release notes
Sourced from loofah's releases.
2.12.0 / 2021-08-11
Features
  • Support empty HTML5 data attributes. [#215]
Changelog
Sourced from loofah's changelog.
2.12.0 / 2021-08-11
Features
Commits
  • 08cc49f version bump to v2.12.0
  • cfd3724 Merge pull request #216 from flavorjones/215-support-empty-data-attributes
  • a6922ce feat: support empty HTML5 data attributes
  • See full diff in compare view
GitHub
