Build(deps): Bump loofah from 2.4.0 to 2.5.0 (PR #9352)
Bumps loofah from 2.4.0 to 2.5.0.
Changelog
Sourced from loofah's changelog.
2.5.0 / 2020-04-05
Features
  • Allow more CSS length units: "ch", "vw", "vh", "Q", "lh", "vmin", "vmax". #178 (Thanks, @JuanitoFatas!)
Fixes
  • Remove comments from Loofah::HTML::Documents that exist outside the html element. #80
Other changes
Commits
  • 2595827 version bump to v2.5.0
  • f47758e ci: update concourse pipelines with latest rubies
  • 9aa508c bug: remove HTML comments that exist outside the html element
  • 5e02888 update CHANGELOG
  • d8ff5ed Merge pull request #180 from JuanitoFatas/remove-tests-from-gem
  • 3133e33 Merge pull request #178 from JuanitoFatas/allow-more-css-values
  • 9c39a16 Merge pull request #181 from JuanitoFatas/fix-metadata
  • 6e26a30 Update URL to hash format to generate metadata
  • 200df2f Revert changes to generated gemspec
  • 3b02e47 Remove test files from final gem
  • Additional commits viewable in compare view
GitHub
