Build(deps): Bump loofah from 2.5.0 to 2.6.0 (PR #10055)
Bumps loofah from 2.5.0 to 2.6.0.
Changelog
Sourced from loofah's changelog.
2.6.0 / 2020-06-16
Features
Commits
  • e48f298 version bump to v2.6.0
  • 4e8a64c ci: update pipeline icon to "cog"
  • c3d8a6d update CHANGELOG
  • 93289f2 dep: update to hoe-markdown ~> v1.2
  • 9ac6450 ci: remove serial group on PR pipeline
  • e14b903 Merge pull request #188 from pipefy/add-css-keywords
  • b519a4a order alphabeticaly
  • 6c329e8 ci: update github icons
  • deb3fa3 maintenance: use hoe-markdown to manage markdown files
  • 296da9b packaging: update gemspec changelog URL
  • Additional commits viewable in compare view
GitHub
