Build(deps): Bump loofah from 2.9.1 to 2.10.0 (PR #13305)
Bumps loofah from 2.9.1 to 2.10.0.
Release notes
Sourced from loofah's releases.
2.10.0 / 2021-06-06
Features
Changelog
Sourced from loofah's changelog.
2.10.0 / 2021-06-06
Features
Commits
  • 6820f9f version bump to v2.10.0, and update CHANGELOG
  • c5fd06e Merge pull request #206 from sampokuokkanen/patch-1
  • f285e64 Update safelist.rb to include overflow-x and y
  • b079e2b Merge pull request #208 from flavorjones/flavorjones-move-to-github-actions
  • 0523e2d ci: create github actions pipeline
  • b14c20e Merge pull request #207 from flavorjones/flavorjones-update-tests-to-pass-wit...
  • fb152b1 test: libxml 2.9.11 handles namespaces in HTML docs differently
  • 3db4cc7 test: unicode every character in the unicode test, for completeness
  • db365d0 Merge pull request #205 from flavorjones/flavorjones-test-unicode-encoded-exp...
  • 895b5f4 test: actually test against a working unicode-encoded exploit
  • See full diff in compare view
GitHub
dependabot/bundler/loofah-2.10.0
