Build(deps): Bump message_bus from 2.2.4 to 3.0.0 (PR #9551)
Bumps message_bus from 2.2.4 to 3.0.0.
Changelog
Sourced from message_bus's changelog.
  • Version 3.0.0
    • Drop support for Ruby 2.3
    • FIX: Don't publish message to intersection of user_ids and group_ids - instead use the union, this is a behavior change, hence a new major release.
26-03-2020
Commits
  • 27fd766 DEV: cut a new release
  • 0d75e8a FIX: Don't publish message to intersection of user_ids and group_ids
  • cf5070b Support for Ruby 2.3 has ended
  • 0082606 Run tests against Ruby 2.6 on CI.
  • 01007ba DEV: Fix broken rubocop rules
  • a26c9d0 DEV: Add missing Rubocop gem dependencies due to changes in discourse config
  • See full diff in compare view
GitHub
Looks like message_bus is up-to-date now, so this is no longer needed.
