Build(deps): Bump message_bus from 3.0.0 to 3.1.0 (PR #9565)
Bumps message_bus from 3.0.0 to 3.1.0.
Changelog
Sourced from message_bus's changelog.
  • Version 3.1.0
    • FEATURE: MessageBus#register_client_message_filter to register a custom filter so that messages can be inspected and filtered away from clients.
27-04-2020
Commits
GitHub
