Build(deps): Bump message_bus from 3.1.0 to 3.2.0 (PR #9695)
Bumps message_bus from 3.1.0 to 3.2.0.
Changelog
Sourced from message_bus's changelog.
  • Version 3.2.0
    • FIX: compatability with Rails 6.0.3, note: apps without ActionDispatch::Flash may stop working after this upgrade to correct this disable middleware injection with config.skip_message_bus_middleware = true and configure middleware by hand with app.middleware.use(MessageBus::Rack::Middleware)
28-04-2020
Commits
GitHub
Looks like message_bus is up-to-date now, so this is no longer needed.
