Build(deps): Bump message_bus from 3.3.2 to 3.3.4 (PR #10816)
Bumps message_bus from 3.3.2 to 3.3.4.
Changelog
Sourced from message_bus's changelog.
  • Version 3.3.4
    • FIX: Remove trailing comma incorrectly added in ec60d8865.
18-09-2020
  • Version 3.3.3
    • FIX: queue_in_memory option not being passed to the backends.
    • FIX: MessageBus::DistributedCache#publish should raise on error.
      On the redis backend, any errors encountered during MessageBus#publish will add the message into an in memory queue and silently swallow the error. While this is behavior is OK for normal message_bus usage, it may lead to inconsistency when using DistributedCache. If a process doesn't publish successfully to another process, it will still update its in memory cache leaving the other processes unaware. As such, the distributed cache is out of sync and will require another successful write to the cache to resync all the caches.
15-09-2020
Commits
  • 11ba4f5 Release 3.3.4.
  • 6b8305d FIX: Remove trailing comma incorrectly added in ec60d8865.
  • 12dd450 Release 3.3.3.
  • 04d2ac0 FEATURE: Add publish_queue_in_memory option to distributed cache manager.
  • 2d6a148 Add missing changelog for e91d41483a89dbcd3a6ecc3aeef47d353b5c6681.
  • e91d414 FIX: MessageBus::DistributedCache#publish should raise on error.
  • ec60d88 FIX: queue_in_memory option not being passed to the backends.
  • 60f8288 Fix failing specs due when stopping MessageBus::TimerThread.
  • 5912973 Add Ruby 2.7 to Travis and remove Ruby 2.4.
  • See full diff in compare view
GitHub
@tgxworld this looks safe, I say we merge
ahh yes. I made the fix last week and decided to wait for dependabot to open the PR :stuck_out_tongue:
