Build(deps): Bump message_bus from 3.3.4 to 3.3.5 (PR #12883)
Bumps message_bus from 3.3.4 to 3.3.5.
Changelog
Sourced from message_bus's changelog.
  • Version 3.3.5
    • PERF: Optimised CORS preflight handling
    • FEATURE: Enable CORS preflight caching
    • FEATURE: Removed trailing cache buster from message bus polls
    • PERF: Improved delay poll timeout for cases where a tab moves in and out of the background
02-10-2020
Commits
  • 50228a2 Bump version and add changelog
  • 992f6de Remove useless assignment
  • f9761cf Remove cache busting implementation from AJAX shim
  • a357a85 Bump version and publish to NPM
  • 570e542 Optimise responses to CORS preflight requests
  • 5c01715 Permit CORS preflight caching
  • e30ed86 Remove live demo, it has been removed
  • a72b930 FIX: force a poll more consistently when visibility changes
  • 5cdba3c DEV: Fix Rubocop runs on Github Actions (#241)
  • adbfd80 DEV: Switch from Travis to Actions (#240)
  • Additional commits viewable in compare view
GitHub
