Build(deps): Bump message_bus from 3.3.5 to 3.3.6 (PR #13215)
Bumps message_bus from 3.3.5 to 3.3.6.
Changelog
Sourced from message_bus's changelog.
  • Version 3.3.6
    • FEATURE: Introduce support for transport codecs
    • FIX: event subscription leak in JS after start/stop/start sequence
    • FEATURE: MessageBus.onVisibilityChange() can be used to trigger a visiblity change check by hand
28-04-2021
Commits
GitHub
