Build(deps): Bump mini_mime from 1.1.0 to 1.1.1 (PR #14125)
Bumps mini_mime from 1.1.0 to 1.1.1.
Changelog
Sourced from mini_mime's changelog.
23-08-2021
  • Version 1.1.1
  • update mime types from upstream
05-04-2021
  • Version 1.1.0
  • MiniMime.lookup_by_extension is now case insensitive
26-03-2021
  • Version 1.0.3
  • Update mime types from upstream
08-07-2019
  • Version 1.0.2
14-08-2018
  • Version 1.0.1
  • Add lookup_by_extension to the public API
08-11-2017
  • Version 1.0.0
  • Other than the version number, no difference from 0.1.4
11-08-2017
  • Version 0.1.4
  • Return preferred extension when looking up by content type
28-03-2016
  • Version 0.1.3
  • Prefer non-obsolete mime types to obsolete ones
14-12-2016
  • Version 0.1.2
  • Backwards compat with ancient Ruby to match mail gem
14-12-2016
  • Version 0.1.1
  • Adjusted API to be more consistent
14-12-2016
  • Version 0.1.0
  • Initial version
Commits
GitHub
