Build(deps): Bump mini_portile2 from 2.5.0 to 2.5.1 (PR #12886)
Bumps mini_portile2 from 2.5.0 to 2.5.1.
Release notes
Sourced from mini_portile2's releases.
2.5.1 / 2021-04-28
Dependencies
This release ends support for ruby < 2.3.0. If you're on 2.2.x or earlier, we strongly suggest that you find the time to upgrade, because official support for Ruby 2.2 ended on 2018-03-31.
Enhancements
  • MiniPortile.execute now takes an optional :env hash, which is merged into the environment variables for the subprocess. Likely this is only useful for specialized use cases. #99
  • Experimental support for cmake-based projects extended to Windows. (Thanks, @​larskanis!)
Changelog
Sourced from mini_portile2's changelog.
2.5.1 / 2021-04-28
Dependencies
Enhancements
Commits
  • 918517d version bump to v2.5.1
  • 88f92a8 fix: #execute should always emit "OK" on success
  • b2730c8 Merge pull request #100 from flavorjones/flavorjones-execute-takes-env-option
  • 1a0d778 feat: #execute now accepts an optional :env hash
  • 0ae074f remove remaining traces of concourse
  • 52ac497 doc: update README with Actions status badge
  • 994abc2 Merge pull request #98 from flavorjones/flavorjones-migrate-to-github-actions
  • 18ddb5c ci: remove appveyor and concourse configs
  • 4b15b72 ci: set makeflags to parallelize builds
  • 963cbb3 ci: skip sqlite and ares examples on windows
  • Additional commits viewable in compare view
GitHub
