Build(deps): Bump mini_portile2 from 2.5.2 to 2.5.3 (PR #13216)
Bumps mini_portile2 from 2.5.2 to 2.5.3.
Release notes
Sourced from mini_portile2's releases.
2.5.3 / 2021-05-31
Make net-ftp an optional dependency, since requiring it as a hard dependency in v2.5.2 caused warnings to be emitted by Ruby 2.7 and earlier. A warning message is emitted if FTP functionality is called and net-ftp isn't available; this should only happen in Ruby 3.1 and later.
Changelog
Sourced from mini_portile2's changelog.
2.5.3 / 2021-05-31
Dependencies
2.6.0 / 2021-05-31
Added
Recipes may build against a local directory by specifying source_directory instead of files. In particular, this may be useful for debugging problems with the upstream dependency (e.g., use git bisect in a local clone) or for continuous integration with upstream HEAD.
Commits
  • b9f0763 version bump to v2.5.3
  • dd5e3dd Merge pull request #106 from flavorjones/105-address-net-ftp-warnings
  • 90a7ea4 dep: make net-ftp an optional dependency
  • 019bd62 chore: remove ruby warning about unused variable
  • See full diff in compare view
GitHub
