Build(deps): Bump mini_racer from 0.2.11 to 0.2.12 (PR #9785)
Bumps mini_racer from 0.2.11 to 0.2.12.
Changelog
Sourced from mini_racer's changelog.
  • 0.2.12
    • FEATURE: isolate.low_memory_notification which can force a full GC
    • FEATURE: MiniRacer::Context.new(ensure_gc_after_idle: 2) - to force full GC 2 seconds after context is idle, this allows you to conserve memory on isolates
  • 14-05-2020
Commits
  • 5f29361 FEATURE: add support for Isolate#low_memory_notification
  • 2d4a760 DEV: update rake dependency
  • See full diff in compare view
GitHub
Superseded by #9787.
