Build(deps): Bump mini_racer from 0.2.11 to 0.2.14 (PR #9788)
Bumps mini_racer from 0.2.11 to 0.2.14.
Changelog
Sourced from mini_racer's changelog.
  • 0.2.14
    • FIX: ensure_gc_after_idle should take in milliseconds like the rest of the APIs not seconds
    • FEATURE: strict params on MiniRacer::Context.new
  • 15-05-2020
  • 0.2.13
    • FIX: edge case around ensure_gc_after_idle possibly firing when context is not idle
  • 15-05-2020
  • 0.2.12
    • FEATURE: isolate.low_memory_notification which can force a full GC
    • FEATURE: MiniRacer::Context.new(ensure_gc_after_idle: 2) - to force full GC 2 seconds after context is idle, this allows you to conserve memory on isolates
  • 14-05-2020
Commits
  • 4f40f41 FIX: to keep api consistent ensure_gc_after_idle should be in ms
  • deab943 FIX: edge case where ensure_gc_after_idle could fire when not idle
  • 5f29361 FEATURE: add support for Isolate#low_memory_notification
  • 2d4a760 DEV: update rake dependency
  • See full diff in compare view
GitHub
Looks like mini_racer is up-to-date now, so this is no longer needed.
