Build(deps): Bump mini_racer from 0.2.14 to 0.2.15 (PR #10142)
Bumps mini_racer from 0.2.14 to 0.2.15.
Changelog
Sourced from mini_racer's changelog.
  • 0.2.15
    • FEATURE: basic wasm support via pump_message_loop
  • 15-05-2020
Commits
GitHub
