Build(deps): Bump mini_racer from 0.2.15 to 0.3.0 (PR #10287)
Bumps mini_racer from 0.2.15 to 0.3.0.
Changelog
Sourced from mini_racer's changelog.
  • 0.3.0
    • FEATURE: upgraded to libv8 version 8.4.255.0
  • 29-06-2020
Commits
GitHub
Looks like mini_racer is up-to-date now, so this is no longer needed.
