Build(deps): Bump mini_racer from 0.2.9 to 0.2.10 (PR #9507)
Bumps mini_racer from 0.2.9 to 0.2.10.
Changelog
Sourced from mini_racer's changelog.
  • 0.2.10
  • 22-04-2020
    • FEATURE: memory softlimit support for nogvl_context_call
Commits
  • b32ca19 bump version
  • 67f40b9 update changelog
  • c25f38b DEV: Ruby 2.3 is EOL no longer officially supported
  • dcf1deb FEATURE: Set memory softlimit in nogvl_context_call also (#161)
  • b457294 DOCS: Update link to V8 flag definitions (#157)
  • 77b8893 DEV: update development dependencies
  • 556d388 Correct links to point to rubyjs
  • 0916139 DEV: No need to check in lock file for example
  • See full diff in compare view
GitHub
