Build(deps): Bump mini_scheduler from 0.12.2 to 0.12.3 (PR #10931)
Bumps mini_scheduler from 0.12.2 to 0.12.3.
Changelog
Sourced from mini_scheduler's changelog.
0.12.3 - 2020-10-15
  • Fixes a problem where scheduler didn't recover from Redis flush
Commits
  • 4f29941 Correct version bump and remove warning from GitHub Actions
  • b24e8e9 Version bump
  • 3298834 Switch badge in README from Travis to GitHub Actions
  • e358bf6 FIX: Scheduler failed to run any jobs after Redis flush (#5)
  • 54be340 Add GitHub Actions for CI and pushing to RubyGems (#6)
  • See full diff in compare view
GitHub
