Build(deps): Bump mini_sql from 0.2.4 to 0.2.5 (PR #9368)
Bumps mini_sql from 0.2.4 to 0.2.5.
Changelog
Sourced from mini_sql's changelog.
2020-04-07 - 0.2.5
  • Added support for custom type maps with Postgres connections
Commits
  • 7a2b379 FEATURE: add support for custom type maps
  • e5d394f FEATURE: empty array encoding compatibility with Sequel and ActiveRecord (#14)
  • 2b147e8 FEATURE: add support query_decorator (#13)
  • 4a940a5 DEV: add rubocop rules
  • ad86f7e FEATURE: add query_array (#10)
  • See full diff in compare view
GitHub
