Build(deps): Bump mini_sql from 0.2.5 to 0.3 (PR #10122)
Bumps mini_sql from 0.2.5 to 0.3.
Changelog
Sourced from mini_sql's changelog.
2020-06-25 - 0.3
  • Added support for query_each and query_each_hash, which lazily queries rows and enables selecting large result sets by streaming
Commits
  • b96bca3 FEATURE: add support for streaming results
  • 7d896b5 DEV: clarify type map is reused
  • dfdb868 DEV: rake dependency was stuck on 10
  • See full diff in compare view
GitHub
@gschlager it looks like you wrote the test that is currently failing with this potential upgrade. Could you look into it please? Thanks!
@eviltrout This spec failure wasn’t related to the gem upgrade. I fixed the root cause in fc8e842773eb4c444d2c4cfdcce63fbc792e1d50
Thanks for the clarification @gschlager
