Build(deps): Bump mixin-deep from 1.3.1 to 1.3.2 (PR #8050)
Bumps mixin-deep from 1.3.1 to 1.3.2.
Commits
Maintainer changes
This version was pushed to npm by doowb, a new releaser for mixin-deep since your current version.
  • @dependabot ignore this [patch|minor|major] version will close this PR and stop Dependabot creating any more for this minor/major version (unless you reopen the PR or upgrade to it yourself)
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
Thanks for contributing this pull request! Could you please sign our CLA so we can review it? http://www.discourse.org/cla
