Build(deps): Bump net-protocol from 0.1.0 to 0.1.1 (PR #13217)
Bumps net-protocol from 0.1.0 to 0.1.1.
Commits
  • 97c4b68 Bump version to 0.1.1
  • 0de81b7 Merge pull request #2 from olleolleolle/patch-1
  • d56f296 CI: Add 3.0 to the matrix
  • d73b077 Don't need to install bundler manually
  • 006f07f Use stable version of actions/checkout
  • 8ecb835 Added dependencies for net-protocol
  • b8d0359 Added LICENSE
  • 9c65bc9 Added the missing licenses field to some default gems
  • 2094370 Fixed the inconsistency gemspec location with net-* gems.
  • a769361 Extract version number from the source
  • Additional commits viewable in compare view
GitHub
Looks like net-protocol is no longer a dependency, so this is no longer needed.
