Build(deps): Bump nio4r from 2.5.2 to 2.5.3 (PR #10620)
Bumps nio4r from 2.5.2 to 2.5.3.
Changelog
Sourced from nio4r's changelog.
2.5.3 (2020-09-07)
Commits
  • 37445cb Bump version.
  • 30b069c Remove ancient appveyor config.
  • efd35cc Prepare CHANGES.md for next release.
  • 507c199 fix for #241
  • 8aa37f3 Fix Actions CI for macOS
  • fec282c ssl_socket_spec.rb - move require inside block
  • 6c6bf29 Fixes for use when OpenSSL is not loaded
  • 6c9ec5e Fix warning: Use result.unpack1("i") instead of result.unpack("i").first....
  • 5c69a73 Setting 'Enabled: false' for the new cops of Rubocop
  • cd63e17 Fix warning: Metrics/LineLength has the wrong namespace - should be Layout
  • Additional commits viewable in compare view
GitHub
