Build(deps): Bump nokogiri from 1.10.9 to 1.10.10 (PR #10171)
Bumps nokogiri from 1.10.9 to 1.10.10.
Release notes
Sourced from nokogiri's releases.
1.10.10 / 2020-07-06
Features
  • [MRI] Cross-built Windows gems now support Ruby 2.7 [#2029]. Note that prior to this release, the v1.11.x prereleases provided this support.
Changelog
Sourced from nokogiri's changelog.
Features
Commits
  • a9a3717 version bump to v1.10.10
  • d2d3c18 update CHANGELOG for v1.10.10
  • f0c324c Merge branch '2029-windows-support-for-ruby-27-on-v110x' into v1.10.x
  • c39e1b0 Support fat binary gems for ruby-2.7
  • 9091602 ci: only manage the v1.10.x pipeline on this branch
  • See full diff in compare view
GitHub
