Build(deps): Bump nokogiri from 1.11.2 to 1.11.3 (PR #12645)
Bumps nokogiri from 1.11.2 to 1.11.3.
Release notes
Sourced from nokogiri's releases.
1.11.3 / 2021-04-07
Fixed
  • [CRuby] Passing non-Node objects to Document#root= now raises an ArgumentError exception. Previously this likely segfaulted. [#1900]
  • [JRuby] Passing non-Node objects to Document#root= now raises an ArgumentError exception. Previously this raised a TypeError exception.
  • [CRuby] arm64/aarch64 systems (like Apple's M1) can now compile libxml2 and libxslt from source (though we continue to strongly advise users to install the native gems for the best possible experience)
Changelog
Sourced from nokogiri's changelog.
1.11.3 / 2021-04-07
Fixed
Commits
  • d244fb8 version bump to v1.11.3
  • 5562eb7 Merge pull request #2215 from sparklemotion/flavorjones-valgrind-test-helpers
  • 72d96fe test: consolidate jruby version info tests
  • d33b021 test: cleanup
  • c75ce9b test: introduce helpers for skips and for a valgrind block
  • cb36a56 ci: make some slow tests run only under NOKOGIRI_GC
  • beb77f5 Merge pull request #2214 from sparklemotion/flavorjones-allow-arm64-compilation
  • 8380a6d fix: update automake files to allow arm64 to compile package libs
  • acfd92c Revert "fix: update automake files to allow arm64 to compile package libs"
  • 65c0ba1 fix: update automake files to allow arm64 to compile package libs
  • Additional commits viewable in compare view
GitHub
