Build(deps): Bump nokogiri from 1.11.4 to 1.11.5 (PR #13107)
Bumps nokogiri from 1.11.4 to 1.11.5.
Release notes
Sourced from nokogiri's releases.
1.11.5 / 2021-05-19
Fixed
[Windows CRuby] Work around segfault at process exit on Windows when using libxml2 system DLLs.
libxml 2.9.12 introduced new behavior to avoid memory leaks when unloading libxml2 shared libraries (see libxml/!66). Early testing caught this segfault on non-Windows platforms (see #2059 and libxml@956534e) but it was incompletely fixed and is still an issue on Windows platforms that are using system DLLs.
We work around this by configuring libxml2 in this situation to use its default memory management functions. Note that if Nokogiri is not on Windows, or is not using shared system libraries, it will will continue to configure libxml2 to use Ruby's memory management functions. Nokogiri::VERSION_INFO["libxml"]["memory_management"] will allow you to verify when the default memory management functions are being used. [#2241]
Added
Nokogiri::VERSION_INFO["libxml"] now contains the key "memory_management" to declare whether libxml2 is using its default memory management functions, or whether it uses the memory management functions from ruby. See above for more details.
Changelog
Sourced from nokogiri's changelog.
1.11.5 / 2021-05-19
Fixed
Added
Commits
  • e43f521 version bump to v1.11.5
  • 42354e4 Merge pull request #2243 from sparklemotion/flavorjones-v1_11_x-update-tests-...
  • 05f30eb update CHANGELOG
  • e6709aa windows: work around libxml2 xmlCleanupParser
  • 8f54c0f test: adjust tests to pass on system libxml2 >= 2.9.11
  • 3d8a570 ci: windows config for github actions
  • 4b9bfe3 update CHANGELOG with the GHSA
  • See full diff in compare view
GitHub
