Build(deps): Bump nokogiri from 1.11.5 to 1.11.6 (PR #13171)
Bumps nokogiri from 1.11.5 to 1.11.6.
Release notes
Sourced from nokogiri's releases.
1.11.6 / 2021-05-26
Fixed
  • [CRuby] DocumentFragment#path now does proper error-checking to handle behavior introduced in libxml > 2.9.10. In v1.11.4 and v1.11.5, calling DocumentFragment#path could result in a segfault.
Changelog
Sourced from nokogiri's changelog.
1.11.6 / 2021-05-26
Fixed
Commits
  • a48c305 version bump to v1.11.6
  • d7b58c3 Merge pull request #2252 from sparklemotion/2250-doc-frag-path-v1_11_x
  • a1b0e6b update CHANGELOG
  • d0f14d1 fix: DocumentFragment#path checks for error case in libxml 2.9.11+
  • See full diff in compare view
GitHub
