Build(deps): Bump nokogiri from 1.11.6 to 1.11.7 (PR #13275)
Bumps nokogiri from 1.11.6 to 1.11.7.
Release notes
Sourced from nokogiri's releases.
1.11.7 / 2021-06-02
  • [CRuby] Backporting an upstream fix to XPath recursion depth limits which impacted some users of complex XPath queries. This issue is present in libxml 2.9.11 and 2.9.12. [#2257]
Checksums
SHA256:
4976a9c9e796527d51dc6c311b9bd93a0233f6a7962a0f569aa5c782461836ef  nokogiri-1.11.7.gem
9d69f57f6c024d86e358a8aef7a273f574721e48a6b2e1426cca007827325413  nokogiri-1.11.7-java.gem
6017dee25feb80292b04554cc1bf8a0a2ede3b6c3daeac811902157bbc6a3bdc  nokogiri-1.11.7-x64-mingw32.gem
38892350c1e695eab9bd77483300d681c32a22714d0e2d04d10a4c343b424bdd  nokogiri-1.11.7-x86-mingw32.gem
1d15603cd878fa2b710a3ba3028a99d9dd0c14b75711faebf9fb6ff40bac3880  nokogiri-1.11.7-x86-linux.gem
7ad9741e7a2fee1ffb4a4b2e20b00e87992c9efd969f557ca3b83fb2653b9bfc  nokogiri-1.11.7-x86_64-linux.gem
c93d66d9413ea7c37d30f95e2c54606fec638e556d454e08124d9a33b7fa82c8  nokogiri-1.11.7-arm64-darwin.gem
8761d9c7baacb26546869ed56dbc78d3eb3cabf49b85d91b1cd827cd6e94fb25  nokogiri-1.11.7-x86_64-darwin.gem
Changelog
Sourced from nokogiri's changelog.
1.11.7 / 2021-06-02
Commits
  • 0a6681e version bump to v1.11.7
  • de0844c test: add coverage for xpath recursion depth fix
  • ed38fea Merge pull request #2258 from sparklemotion/2257-libxml2-xpath-recursion-limi...
  • 1f6c661 fix: upstream libxml2 bug in calculating xpath query recursion depth
  • See full diff in compare view
GitHub
