Build(deps): Bump nokogiri from 1.12.0 to 1.12.1 (PR #13932)
Bumps nokogiri from 1.12.0 to 1.12.1.
Release notes
Sourced from nokogiri's releases.
1.12.1 / 2021-08-03
Fixed
  • Fix compilation of libgumbo on BSD systems by avoiding GNU-isms. [#2298]
Checksums:
194092568135d7897d8df0472c27c82b395a6c09054b8f4e8929805faf9eb877  nokogiri-1.12.1-arm64-darwin.gem
e9e16b36f6528af16c62bcfaeae517badb1ec07f5e856b5c151a913d3b0e6368  nokogiri-1.12.1-java.gem
ee1c497c759fdbbe482ab8a0c497b75d44efce5d2ae20fdb93b8c225508dc75a  nokogiri-1.12.1-x64-mingw32.gem
30c7dff0c9a56a2f03e4e4aa029e14f15282af37d469a0b159446de4c500b28b  nokogiri-1.12.1-x86-linux.gem
fcbdfc03405624ec0a186fa1bb41111a27264f4e7a7398c64c0d4e1e83769739  nokogiri-1.12.1-x86-mingw32.gem
ee4c88c46b8797bc6dbeee233ef0862a34d8a1a799e9fdcdfb0dfd8a42bb629b  nokogiri-1.12.1-x86_64-darwin.gem
f861b04e3268bda45036907f56ceede16b9fe1969099cb8888d378f71706fc63  nokogiri-1.12.1-x86_64-linux.gem
66dc1f0aa02fc62efb166465dfcc520785068cce4a9a3d2822cdea1f1ce66775  nokogiri-1.12.1.gem
Changelog
Sourced from nokogiri's changelog.
1.12.1 / 2021-08-03
Fixed
Commits
  • 3457f44 version bump to v1.12.1
  • 0e5fece Merge pull request #2299 from sparklemotion/flavorjones-bsd-gumbo-support
  • 1159a9b ext(gumbo): avoid Gnu-isms in the Makefile
  • 2e7ab22 ext(gumbo): Makefile variable override is not necessary
  • 66dace2 ci: add coverage for freebsd
  • 6e87b67 test: add freebsd to the vagrantfile for testing
  • See full diff in compare view
GitHub
