Build(deps): Bump nokogiri from 1.12.1 to 1.12.2 (PR #13948)
Bumps nokogiri from 1.12.1 to 1.12.2.
Release notes
Sourced from nokogiri's releases.
1.12.2 / 2021-08-04
Fixed
  • Ensure that C extension files in non-native gem installations are loaded using require and rely on $LOAD_PATH instead of using require_relative. This issue only exists when deleting shared libraries that exist outside the extensions directory, something users occasionally do to conserve disk space. [#2300]
Checksums:
2ef276b482b56cfa488dd24c261c0bf42a47770bd0c15993f5c0d8b61879c114  nokogiri-1.12.2-arm64-darwin.gem
b483fb44ca38ba5890d53a16ab06e56cb23e6facc861ad1260c7bdf45d8227a2  nokogiri-1.12.2-java.gem
254e63ce59f95a4c30721d9ec85f8eb5e5e4f61e8da35015e41b85a262c014ea  nokogiri-1.12.2-x64-mingw32.gem
f66fbeca97668d3b6563d9311fe59b3dda5f7177405ec7a4d9dceca9d8d23b23  nokogiri-1.12.2-x86-linux.gem
0ece40121d72ab9704e429e06aa2011c7c59112886e000e3dac4ded3f3aeb3d6  nokogiri-1.12.2-x86-mingw32.gem
b9e33ebbb6c5b7575cfcb69bb52f776541642bbed08c88a36c1a33718458a8b9  nokogiri-1.12.2-x86_64-darwin.gem
bd8e7eb8345ef0679f2db3afa2bc13d7338b786c51aaa05ac6e22c1c8da3f3b3  nokogiri-1.12.2-x86_64-linux.gem
94a219a8078bf55f10834445be61b3ad9aa1e1047ec1bed048a86e3ab3245bc5  nokogiri-1.12.2.gem
Changelog
Sourced from nokogiri's changelog.
1.12.2 / 2021-08-04
Fixed
Commits
  • f1a5cae version bump to v1.12.2
  • c77b0b0 Merge pull request #2301 from sparklemotion/2300-extension-location
  • 35f2f7a ext: load C extension files from non-native gems via "require"
  • 7776f51 dev: scripts/build-gems emits checksums after building
  • See full diff in compare view
GitHub
