Build(deps): Bump nokogiri from 1.12.4 to 1.12.5 (PR #14451)
Bumps nokogiri from 1.12.4 to 1.12.5.
Release notes
Sourced from nokogiri's releases.
1.12.5 / 2021-09-27
Security
[JRuby] Address CVE-2021-41098 (GHSA-2rr5-8q37-2w7h).
In Nokogiri v1.12.4 and earlier, on JRuby only, the SAX parsers resolve external entities (XXE) by default. This fix turns off entity-resolution-by-default in the JRuby SAX parsers to match the CRuby SAX parsers' behavior.
CRuby users are not affected by this CVE.
Fixed
  • [CRuby] Document#to_xhtml properly serializes self-closing tags in libxml > 2.9.10. A behavior change introduced in libxml 2.9.11 resulted in emitting start and and tags (e.g., <br></br>) instead of a self-closing tag (e.g., <br/>) in previous Nokogiri versions. [#2324]
SHA256 checksums:
36bfa3a07aced069b3f3c9b39d9fb62cb0728d284d02b079404cd55780beaeff  nokogiri-1.12.5-arm64-darwin.gem
16b1a9ddbb70a9c998462912a5972097cbc79c3e01eb373906886ef8a469f589  nokogiri-1.12.5-java.gem
218dcc6edd1b49cc6244b5f88afb978739bb2f3f166c271557fe5f51e4bc713c  nokogiri-1.12.5-x64-mingw32.gem
e33bb919d64c16d931a5f26dc880969e587d225cfa97e6b56e790fb52179f527  nokogiri-1.12.5-x86-linux.gem
e13c2ed011b8346fbd589e96fe3542d763158bc2c7ad0f4f55f6d801afd1d9ff  nokogiri-1.12.5-x86-mingw32.gem
1ed64f7db7c1414b87fce28029f2a10128611d2037e0871ba298d00f9a00edd6  nokogiri-1.12.5-x86_64-darwin.gem
0868c8d0a147904d4dedaaa05af5f06656f2d3c67e4432601718559bf69d6cea  nokogiri-1.12.5-x86_64-linux.gem
2b20905942acc580697c8c496d0d1672ab617facb9d30d156b3c7676e67902ec  nokogiri-1.12.5.gem
Changelog
Sourced from nokogiri's changelog.
1.12.5 / 2021-09-27
Security
Fixed
Commits
  • 47f6a46 version bump to v1.12.5
  • 2a0ac88 update CHANGELOG
  • 6b60637 Merge pull request #2329 from sparklemotion/flavorjones-GHSA-2rr5-8q37-2w7h_1...
  • 4bd943c fix(jruby): SAX parser uses an entity resolver
  • f943ee4 refactor(jruby): handle errors more consistently
  • 2790122 format: test files
  • 01e1618 Merge pull request #2327 from sparklemotion/2324-xhtml-self-closing-tags_v1.12.x
  • a0180c7 fix: HTML4::Document.to_xhtml self-closing tags
  • See full diff in compare view
GitHub
