Build(deps): Bump nokogiri from 1.12.5 to 1.13.0 (PR #15480)
Bumps nokogiri from 1.12.5 to 1.13.0.
Release notes
Sourced from nokogiri's releases.
1.13.0 / 2022-01-06
Notes
Ruby
This release introduces native gem support for Ruby 3.1. Please note that Windows users should use the x64-mingw-ucrt platform gem for Ruby 3.1, and x64-mingw32 for Ruby 2.6–3.0 (see RubyInstaller 3.1.0 release notes).
This release ends support for:
Faster, more reliable installation: Native Gem for ARM64 Linux
This version of Nokogiri ships experimental native gem support for the aarch64-linux platform, which should support AWS Graviton and other ARM Linux platforms. We don't yet have CI running for this platform, and so we're interested in hearing back from y'all whether this is working, and what problems you're seeing. Please send us feedback here: Feedback: Have you used the aarch64-linux native gem?
Publishing
This version of Nokogiri opts-in to the "MFA required to publish" setting on Rubygems.org. This and all future Nokogiri gem files must be published to Rubygems by an account with multi-factor authentication enabled. This should provide some additional protection against supply-chain attacks.
A related discussion about Trust exists at #2357 in which I invite you to participate if you have feelings or opinions on this topic.
Dependencies
Improved
  • {XML,HTML4}::DocumentFragment constructors all now take an optional parse options parameter or block (similar to Document constructors). [#1692] (Thanks, @​JackMc!)
  • Nokogiri::CSS.xpath_for allows an XPathVisitor to be injected, for finer-grained control over how CSS queries are translated into XPath.
  • [CRuby] XML::Reader#encoding will return the encoding detected by the parser when it's not passed to the constructor. [#980]
  • [CRuby] Handle abruptly-closed HTML comments as recommended by WHATWG. (Thanks to tehryanx for reporting!)
  • [CRuby] Node#line is no longer capped at 65535. libxml v2.9.0 and later support a new parse option, exposed as Nokogiri::XML::ParseOptions::PARSE_BIG_LINES, which is turned on by default in ParseOptions::DEFAULT_{XML,XSLT,HTML,SCHEMA} (Note that JRuby already supported large line numbers.) [#1764, #1493, #1617, #1505, #1003, #533]
  • [CRuby] If a cycle is introduced when reparenting a node (i.e., the node becomes its own ancestor), a RuntimeError is raised. libxml2 does no checking for this, which means cycles would otherwise result in infinite loops on subsequent operations. (Note that JRuby already did this.) [#1912]
  • [CRuby] Source builds will download zlib and libiconv via HTTPS. ("ruby" platform gem only.) [#2391] (Thanks, @​jmartin-r7!)
  • [JRuby] Node#line behavior has been modified to return the line number of the node in the final DOM structure. This behavior is different from CRuby, which returns the node's position in the input string. Ideally the two implementations would be the same, but at least is now officially documented and tested. The real-world impact of this change is that the value returned in JRuby is greater by 1 to account for the XML prolog in the output. [#2380] (Thanks, @​dabdine!)
Fixed
  • CSS queries on HTML5 documents now correctly match foreign elements (SVG, MathML) when namespaces are not specified in the query. [#2376]
  • XML::Builder blocks restore context properly when exceptions are raised. [#2372] (Thanks, @​ric2b and @​rinthedev!)
  • The Nokogiri::CSS::Parser cache now uses the XPathVisitor configuration as part of the cache key, preventing incorrect cache results from being returned when multiple XPathVisitor options are being used.
  • Error recovery from in-context parsing (e.g., Node#parse) now always uses the correct DocumentFragment class. Previously Nokogiri::HTML4::DocumentFragment was always used, even for XML documents. [#1158]
... (truncated)
Changelog
Sourced from nokogiri's changelog.
1.13.0 / 2022-01-06
Notes
Ruby
Publishing
Dependencies
Improved
Fixed
... (truncated)
Commits
  • be17829 version bump to v1.13.0
  • 98b07c7 dev: make manual gem packaging more reliable
  • d92feaf Merge pull request #2411 from sparklemotion/dependabot/bundler/rake-compiler-...
  • 43dd7cb build(deps-dev): update rake-compiler requirement from = 1.1.6 to = 1.1.7
  • dc5276f Merge pull request #2409 from larskanis/cross-ruby-3.1
  • 56b89d9 package: native win gem correctly specifies required ruby version
  • a76963c update CHANGELOG with ruby 3.1 native gem support
  • c6f195a style: sort .cross_rubies
  • d5584a7 package: move host hack into the libiconv recipe
  • bc3e640 ci: remove workaround for RCD runas
  • Additional commits viewable in compare view
GitHub
This wasn’t supposed to be a compatibility-breaking release :thinking: Who wants to dig in and report the issue?
Reported in [bug] Regression in 1.13.0 in DocumentFragment#css? · Issue #2419 · sparklemotion/nokogiri · GitHub
This feels very risky for 2.8, pushing this to 2.9
Yeah, we’re waiting on 1.13.1
Superseded by #15573.
