Build(deps): Bump nokogumbo from 2.0.2 to 2.0.3 (PR #11317)
Bumps nokogumbo from 2.0.2 to 2.0.3.
Release notes
Sourced from nokogumbo's releases.
Version 2.0.3
[2.0.3] - 2020-11-21
Added
  • Limit enforced on number of attributes per element, defaulting to 400 and configurable with the :max_attributes argument.
Fixed
  • Ignore UTF-8 byte order mark at the beginning of the input.
  • Fix content sniffing for Unicode strings.
  • Fixed crash where Ruby objects constructed in C can be garbage collected.
Changelog
Sourced from nokogumbo's changelog.
Added
Fixed
Commits
  • 2dc79ca Bump version to 2.0.3
  • a624096 Wrap ParseArgs in a Ruby object
  • 55d7b96 Add test for #150
  • 9b5a886 Register all global VALUES as mark objects
  • 28c5940 Add README documentation and changelog entry about attribute limit
  • 66b8fad Fix extra spaces
  • 7c0069f Raise ArgumentError instead of ignoring attributes above limit
  • b903745 Limit number of attributes per element to prevent DoS
  • b41e791 Update README.md
  • 8c7a93f Fix content-sniffing for Unicode strings
  • Additional commits viewable in compare view
GitHub
The failure is a regression in nokogumbo:
# 2.0.2
Nokogiri::HTML5::fragment(nil)
# => #<Nokogiri::HTML5::DocumentFragment:0x3fda6e849f80 name="#document-fragment">
# nokogumbo 2.0.3
# => NoMethodError (undefined method `to_str' for nil:NilClass)
I dunno, should we be parsing nil? @lis2 can you fix this? Perhaps we report this regression to nokogumbo as well while at it.
The upgrades sounds important to me.
@jbrw this is the same upgrade here (as a separate PR) that I mentioned. @lis2 might be looking into it.
closing, @lis2 has a separate PR to fix.
OK, I won’t notify you again about this release, but will get in touch when a new version is available.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
