Build(deps): Bump oauth from 0.5.6 to 0.5.7 (PR #14799)
Bumps oauth from 0.5.6 to 0.5.7.
Changelog
Sourced from oauth's changelog.
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
[Unreleased]
Added
Changed
Fixed
Removed
Commits
  • 2310357 🔀 Merge pull request #228 from oauth-xx/issue/227-prepare-release-0.5.7
  • 01efef4 Bump oauth to 0.5.7
  • 9407be8 📝 Document fixes to constant lookups
  • c299653 📝 Document maintenance branch is not latest release
  • 46e348e 📝 Document maintenance branch names
  • fda4f90 🔀 Merge pull request #226 from oauth-xx/issue/225-backports-to-v0.5
  • 8270595 🔧 Ignore style issues raised by tweaking backports for older Rubies
  • ee9345b 📝 Document Ruby compatibility matrix
  • ac5258f 🐛 Fix request proxy Class constant reference scopes
  • 41d6560 🔥 Remove bad/disabled test
  • Additional commits viewable in compare view
GitHub
