Build(deps): Bump oauth from 0.5.7 to 0.5.8 (PR #14877)
Bumps oauth from 0.5.7 to 0.5.8.
Changelog
Sourced from oauth's changelog.
[0.5.8] 2021-11-10
Added
  • Added more documentation files to packaged gem, e.g. SECURITY.md, CODE_OF_CONDUCT.md
Fixed
  • Removed reference to RUBY_VERSION from gemspec, as it depends on rake release, which is problematic on some ruby engines. (by @​pboling)
Commits
  • 018f1e8 Bump oauth to 0.5.8
  • d50409c ✨ CHANGELOG for release 0.5.8
  • 5fb1d03 🐛 Fix Danger
  • 18849af 🎨 Cleanup default Dangerfile
  • 9e2b584 🐛 RUBY_VERSION depends on rake release so remove from gemspec
  • be296cb ✨ Ship SECURITY and CONTRIBUTING with packaged gem
  • 14cff2e ✨ What's up Danger?
  • d5d24ea 🎨 Link Cleanup
  • e928e98 🐛 Add missing links
  • 0b5f8d3 ✨ Add Danger Analysis
  • Additional commits viewable in compare view
GitHub
