Build(deps): Bump oj from 3.10.18 to 3.11.0 (PR #11710)
Bumps oj from 3.10.18 to 3.11.0.
Changelog
Sourced from oj's changelog.
3.11.0 - 2020-01-12
  • Added :compat_bigdecimal to support the JSON gem :decimal_class undocumented option.
  • Reverted the use of :bigdecimal_load for :compat mode.
Commits
GitHub
