Build(deps): Bump oj from 3.10.5 to 3.10.6 (PR #9351)
Bumps oj from 3.10.5 to 3.10.6.
Changelog
Sourced from oj's changelog.
3.10.6 - 2020-04-04
  • Correct object dump code to continue instead of return on an _ attribnute.
Commits
GitHub
