Build(deps): Bump oj from 3.10.6 to 3.10.7 (PR #10227)
Bumps oj from 3.10.6 to 3.10.7.
Changelog
Sourced from oj's changelog.
3.10.7 - 2020-07-13
  • Faster float parsing and an adjust to more closely match Ruby.
Commits
GitHub
Looks like a safe change, merging.
