Build(deps): Bump oj from 3.10.8 to 3.10.9 (PR #10460)
Bumps oj from 3.10.8 to 3.10.9.
Changelog
Sourced from oj's changelog.
3.10.9 - 2020-08-17
  • Add bigdecimal dependency to gemfile.
Commits
  • 02ece7f release prep
  • fb5e278 Add dependency on bigdecimal
  • 4a3dfc5 Use Ruby for dumping floats in compat mode
  • 2710b1d Remove float from mimic test
  • 3c1c896 Give up on compat mode and just use ruby string to_f
  • See full diff in compare view
GitHub
