Build(deps): Bump oj from 3.11.3 to 3.11.4 (PR #12726)
Bumps oj from 3.11.3 to 3.11.4.
Changelog
Sourced from oj's changelog.
3.11.4 - 2021-04-14
  • Code re-formatted with clang-format. Thanks goes to BuonOmo for suggesting and encouraging the use of a formatter and getting the effort started.
  • Added support for GC.compact on Oj::Doc
  • Fixed compatibility issue with Rails and the JSON gem that requires a special case when using JSON.generate versus call to_json on an object.
Commits
GitHub
There’s 3.11.5 already that fixes a bug introduced in 3.11.4. Let’s see if @dependabot recreate will pick it up. :slightly_smiling_face: (and whether dependabot commands work mid-sentence :stuck_out_tongue:)
Superseded by #12732.
