Build(deps): Bump oj from 3.11.6 to 3.11.7 (PR #13487)
Bumps oj from 3.11.6 to 3.11.7.
Changelog
Sourced from oj's changelog.
3.11.7 - 2021-06-22
  • Fixed exception type when parsing after Oj::Rails.mimic_JSON is called.
Commits
GitHub
