Build(deps): Bump oj from 3.11.7 to 3.11.8 (PR #13629)
Bumps oj from 3.11.7 to 3.11.8.
Changelog
Sourced from oj's changelog.
3.11.8 - 2021-07-03
  • Fixed or reverted change that set the default mode when optimize_Rails was called.
Commits
GitHub
