Build(deps): Bump oj from 3.11.8 to 3.12.0 (PR #13651)
Bumps oj from 3.11.8 to 3.12.0.
Changelog
Sourced from oj's changelog.
3.12.0 - 2021-07-05
  • Added string and symbol caching options that give Oj about a 20% parse performance boost.
Commits
GitHub
