Build(deps): Bump oj from 3.12.0 to 3.12.1 (PR #13698)
Bumps oj from 3.12.0 to 3.12.1.
Changelog
Sourced from oj's changelog.
3.12.1 - 2021-07-09
  • Fixed :cache_keys not being honored in compat mode.
  • Increased the cache size.
Commits
GitHub
