Build(deps): Bump oj from 3.12.2 to 3.12.3 (PR #13934)
Bumps oj from 3.12.2 to 3.12.3.
Changelog
Sourced from oj's changelog.
3.12.3 - 2021-08-02
  • Update documents for the :cache_keys and :cache_strings.
  • Watson1978 increasd dump performance for rails mode.
Commits
GitHub
