Build(deps): Bump oj from 3.13.2 to 3.13.3 (PR #14202)
Bumps oj from 3.13.2 to 3.13.3.
Changelog
Sourced from oj's changelog.
3.13.3 - 2021-08-30
  • Caches are now self adjusting and clearing so less used entries are expunged to avoid memory growth.
  • When mimicking the JSON gem the JSON::State now handles all Hash methods. While this is different than the actually JSON gem it avoids failing due to errors in Rails code and other gems.
Commits
GitHub
