Build(deps): Bump omniauth-facebook from 6.0.0 to 7.0.0 (PR #10528)
Bumps omniauth-facebook from 6.0.0 to 7.0.0.
Changelog
Sourced from omniauth-facebook's changelog.
7.0.0 (2020-08-03)
Changes:
  • bumped version of FB Graph API to v4.0
Commits
GitHub
