Build(deps): Bump omniauth-facebook from 8.0.0 to 9.0.0 (PR #14712)
Bumps omniauth-facebook from 8.0.0 to 9.0.0.
Changelog
Sourced from omniauth-facebook's changelog.
9.0.0 (2021-10-25)
Changes:
  • bumped version of FB Graph API to v5.0
Commits
GitHub
